JRL:
Just spent some time looking at Soric. Thanks for thinking
about it with me in mind. I have always thought poly honeycomb
would be the core of choice for a composite kayak. I had been
looking a Nida-Coreās scrimed honeycomb core, are any of you
using either of these products?
I have been trying to see the light (no pun intended) for the
vacuum infusion process for my project.
Please correct me if I am mistaken.
It seems as though the resin uptake is significant for an
infusion process at 1 kg/m^2 or 2.2 lbs. My āyak (18ā tandem,
24"W w/12-14" sides) will have approximately 11 meters (6 hull +
5 deck) of core material. If that is right it will uptake an additional
11 kilos in resin. :eek: 11k*2.2lb = 24.2 lbs. of resin or
24.2 lbs/8.8 lbs/gal is 2.75 gallons of resin! :eek:
Is this correct? I thought it would be lots better (lighter) than that.
My assumptions come from this product sheet:
http://www.lantor.nl/files_cms/bestand/40993.pdf
(I just went back to review the sheet and it lists the impregnated density of Soric
at 600 kg/m^3. So 11yds * .25" = approx 3"; 36"/3" = approx.
1/12 of a cubic meter. 600kg/12 = 50kg! which is even worse at
110 lbs. What is wrong with this calculation?)
What can I expect for resin usage/weight if I infuse about 33
yds. of CF/Kevlar hybrid cloth? Is that 6 oz * 33 yds / 16 oz/lb = 12.375 lbs.?
Thatās 2 layers on the outside of hull
and 1 everywhere else, (inside of hull, in & out of deck) Will this layup work
or does it need to be the same in and out of hull for the core to work?
I am concerned about rock impacts at 6-8 NM/hr.
Iām sooo confused! :o
It looks as though prepreg is still the best option if I am to
build a light (40lbs) racing craft.
Thanks for letting think out loudā¦
Jim
