I have a small shop in my home garage
6 Hp, 220 v, 30 gal Compressor (11 CFM @ 90 psi)
Air tools:
HVLP Sprayer (Harbor Freight - HF)
Air Saw - HF
Air Grinder - HF
Two 6" air sanders - palm style Ingersoll Rand
Water/Air filter for paint gun line
In-line oiler for tool line
I don’t recommend the inexpensive plastic air hoses, stick with the rubber ones. The plastic ones have a coil memory that just plain sucks.
Robinair 15600 Vacuum pump w/ a home made vacuum reservoir system
Resin infusion resevoir AKA paint pot 2-1/2 gal Craftsman.
Dremel tool
2 Hand power drills
Grizzly 14" bandsaw, 1 hp, w/ 6" riser. I’ll post the blade I use when I get a chance to look at the specs.
Drill Press, 1 HP, 16 speed 17" swing Central Machinery (aka HF)
10" table saw
6" jointer
13" planer
Oscillating Spindle Sander
Benchtop Belt & Disc sander
Several hand sanding blocks & a couple of long fairing boards
Lots & lots of sandpaper. Lately I’ve had good luck with Klingspor brand.
2 Craftsman workmate portable tool benches.
2 Workbenches with 4’ x 8’ melamine tops.
Digital Caliper 6" (HF for $14.99) best buy!!!
Clamps too numerous to mention
Hot air gun
Hot glue gun
Several sheetmetal vise grips for clamping vacuum & resin lines
Standard plethora of mechanics tools.
A lot of my tools have been purchased at Harbor Frieght only after seeing favorable recommendations on the 'net that they weren’t junk. The money saved can be pretty impressive if you only plan on using a tool for an occasional odd project. Numerous other items I’ve gotten off of ebay for excellent savings (Vacuum pump, vacuum oil, air sanders, etc).
