Tools and their intent to do harm....
From an ACVW buddy of mine:
This is an old list, but I thought that it was worthwhile to repost.
Tool Definitions:
  1. DRILL PRESS: A tall upright machine useful for suddenly snatching
    flat metal bar stock out of your hands so that it smacks you in the chest
    and flings your beer across the room, splattering it against that freshly
    painted part you were drying.
  2. WIRE WHEEL: Cleans rust off old bolts and then throws them
    somewhere under the workbench with the speed of light. Also removes fingerprint
    whorls and hard-earned guitar calluses in about the time it takes you to say,
    “Ouch…”
  3. ELECTRIC HAND DRILL: Normally used for spinning steel pop rivets in
    their holes until you die of old age
  4. PLIERS: Used to round off bolt heads.
  5. HACKSAW: One of a family of cutting tools built on the Ouija board
    principle. It transforms human energy into a crooked, unpredictable
    motion and the more you attempt to influence its course, the more dismal your
    future becomes.
  6. VISE-GRIPS: Used to round off bolt heads. If nothing else is
    available, they can also be used to transfer intense welding heat to the palm of
    your hand.
  7. OXYACETYLENE TORCH: Used almost entirely for lighting various
    flammable objects in your garage on fire. Also handy for igniting the grease
    inside a brake drum you’re trying to get the bearing race out of.
  8. WHITWORTH SOCKETS: Once used for working on older British cars and
    motorcycles, they are now used mainly for impersonating that 9/16 or
    1/2 socket you’ve been searching for the last 15 minutes.
  9. HYDRAULIC FLOOR JACK: Used for lowering a motorcycle to the ground
    after you have installed your new front disk brake setup, trapping the jack
    handle firmly under the front fender.
  10. EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a motorcycle
    upward off a hydraulic jack.
  11. TWEEZERS: A tool for removing wood splinters.
  12. PHONE: Tool for calling your neighbor to see if he has another
    hydraulic floor jack.
  13. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool
    for spreading mayonnaise; used mainly for getting dog-do off your boot.
  14. E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt
    holes and is ten times harder than any known drill bit.
  15. TIMING LIGHT: A stroboscopic instrument for illuminating grease
    buildup.
  16. TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the
    tensile strength of ground straps and brake lines you may have forgotten to
    disconnect.
  17. CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying
    tool that inexplicably has an accurately machined screwdriver tip on the
    end without the handle.
  18. BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric
    acid from a car battery to the inside of your toolbox after determining
    that your battery is dead as a doornail, just as you thought.
  19. AVIATION METAL SNIPS: See hacksaw.
  20. TROUBLE LIGHT: The mechanic’s own tanning booth. Sometimes called
    drop light, it is a good source of vitamin D, “the sunshine vitamin,” which
    is not otherwise found under motorcycles at night. Health benefits aside,
    it’s main purpose is to consume 40-watt light bulbs at about the same
    rate that 105-mm howitzer shells might be used during, say, the first few
    hours of the Battle of the Bulge. More often dark than light, its name is
    somewhat misleading.
  21. PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
    paper-and-tin oil cans and splash oil on your shirt; can also be used,
    as the name implies, to round off Phillips screw heads.
  22. AIR COMPRESSOR: A machine that takes energy produced in a
    coal-burning power plant 200 miles away and transforms it into compressed air that
    travels by hose to a Chicago Pneumatic impact wrench that grips rusty
    bolts last tightened 40 years ago by someone in Sindelfingen, and
    effortlessly rounds them off.
  23. PRY BAR: A tool used to crumple the metal surrounding that clip or
    bracket you needed to remove in order to replace a 50 cent part.
  24. HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
  25. HAMMER: Originally employed as a weapon of war, the hammer
    nowadays is used as a kind of divining rod to locate expensive parts not far from
    the object we are trying to hit.
  26. MECHANIC’S KNIFE: Used to open and slice through the contents of
    cardboard cartons delivered to your front door; works particularly
    well on boxes containing seats and motorcycle jackets.
BTT:rolleyes:
THAT is what I needed this morning.
