Untill recently most of my projects have been quite small and almost exclusively made of carbon. However I have been creating something a bit different over the last few weeks and the final piece has many more layers in the composition and is over 50% Kevlar.
Now on a material test sample I made before this piece I found that the Kevlar was unsurprisingly much harder to cut than the carbon once cured. I have been using a Dremel with Tungsten Carbide cutting wheels from http://www.permagrit.com/ which works fine on pure carbon pieces/
I am reasonably certain my current tools will not be able to cut through my new layup. Does any one have any recommendations as to the best way to cut a piece which has a large amount of Kevlar (6 x 175 GSM plain weave layers)?
(wet) sand with a very fine grit (1000-1500) afterwards to get rid of most loose fibres.
