Available in 2 versions, room temp and high temp tooling compound. It’s basically a 2 part polyurethane foam mixed with epoxy tooling resin. Mix the 2 parts together and you have a dough like compound that you can use to reinforce your mold.
Pros:
Add strength and stiffness without the weight
Reduce overall time it takes to build the mold
Reduced mold cost
Great for reinforcing sharp corners and hard to get into places
Cons:
Epoxy based so it’s for epoxy tooling only
Quick rundown:
- Tooling gel coat
- 2 plies of fiberglass cloth
- Tooling compound (no thicker than 1/2")
Example: Here is a motor hood mold that I made on Saturday. The entire top side of the mold was done in half a day from brushing on the tooling gel coat to the last 2 plies of fiberglass cloth. Overall this mold only has 4 plies of 8oz glass, yet it is stiff like a mother. The tooling compound was only applied to 1/4" thick.
