Hello,
I have been using a vacuum system to create some tubes for a bike. My main concern is that the tubes are coming out dry. My method currently is to cut foam cores, wrap with carbon fiber while wetting out, wrap in nylon peel ply and then bag it.
On one batch of parts, there are some sections where I can feel carbon threads but it seems saturated and hard. On the first bag I did, the entire tube has the texture from the peel ply and I am very satisfied from the result. This tube can be seen on the right of the image. The next left two are from the same batch and are questionable quality.
High Resolution: http://i.imgur.com/BlLiMJG.jpg
My main questions are:
[ol]
[li]Should the parts look like the one on the right?
[/li][li]How saturated should the fibers be during layup?
[/li][li]What’s the best method for wrapping the carbon tightly around the tubes so that it doesn’t wrinkle?
[/li][li]How do I prevent the peelply from moving while in the vacuum bag?
[/li][/ol]
