I received a call from a potential customer this morning. He has a stock KTM gas tank with the internal resin flaking off. This tank has a history. He purchased the bike new and the first tank began to leak after a couple of weeks. KTM replaced it with this one but it began to leak as well. He sent it in and after 8 months it came back with a new internal coating. Apparently, they use an incompatible resin system, which is being broken down by gasoline. The OEM that produced the tank went out of business and so he is stuck with the potion of replacing with a different tank, which is smaller. He wants to keep this one and asked me if it is repairable.
Has anyone here tried a repair like this before? If yes how did you do it? It’s going to be impossible to remove the old resin without cutting the tank open so my first thought would be to split the tank, sand out the old coating, reassemble it and re-coat it. I don’t see any reason why that wouldn’t work but maybe someone here has a better idea.
Likely the safest option would be to make new tank using the old a plug.
