Generally if I spray gel coat it goes in a mold. I did some overlays (under vacuum) and wanted to spray them with clear gel. I have a gravity feed HVPL gun (2.5mm tip), PE Clear Gel and Duratec high gloss additive.
I sprayed it once already. Got a lot of orange peel. I think my pressure was to high. Wet sanded to 400. Now I’m looking for the best method for a good wet on wet build and minimal surface finishing.
Would a small amount of thinner or reducer work. Thinking that once the first coat flashes I could add another…
Looking for directed to speed the learning curve
Jeff
