If I am using Silmar 249 with MEKP, how long should I wait between applying coats of resin to a part? I am making a set of overlay mirror covers for my truck.
Here are the steps I think I should follow:
-Sand the mirror caps with 80 grit,
-Tape the underside off to prevent resin runs,
-Add resin (no wax) to sanded surface and wait until it’s tacky,
-Stick CF onto tacky resin and use a paintbrush to push it smooth,
-trim edges of CF cloth
-add several coats of resin (wax in last one)
-sand smooth and decide if I need more coats of resin
-once happy with the thickness sand smooth and clear coat
My two biggest questions are with the Silmar 249…
how long should I wait after painting resin on should I wait to paint more on? (Time between resin coats?)
How long after the last coat with wax and wet sand should I wait to clear coat?
Sent from my iPhone using Tapatalk
