Hey Jim,
Even show me some of the tooling dough also and we built up a door mold using the stuff. It is from PTM&W and is called RTC???. I think it is on the specialty section. It is an epoxy based putty that has a yellow and blue part that are mixed 1:1 to make a green dough. We were able to put down two layers glass, dough, and two more layers and the mold was super strong. We put the dough down at about 1/4 inch or a little more.
For the poly mold above, I put down about 25 mils of tooling get, let that set up till it was firm to the touch (1.5 hours given the shop temp/humidity). I put the gel down with a gel coat gun. I would not recommend trying to brush something this big. If the gel coat gets too thick it can blister. Also, watch your catalyst level and build the layers slowly. Once the gel coat was stable, I put down two layers of surface veil to stabilize the gel coat. I then let this cure out, then two layers chopped strand mat, cure, two more, cure, then poured the 8lb foam over the entire surface while still soupy which self levels. Let the foam cure, then two more layers. Then made large X brace with foam and beveled edges and covered with three layers. Done. The thing still weighs a ton but there is no flex in this mold and should be good for several hoods.
