When you shoot Duratec Surfacing Primer, which of the recommended thinners do you use (MEK, fast acrylic laquer thinner, or ?) and what’s the viscosity (if you test it!).
I know from searching the threads that Evan’s using an HVLP gun with a 2 mm tip. I just bought a gravity fed HVLP gun w/ a 1.4 & 2.2 mm tip and I’m curious how successful others are with similar setups.
Any other spraying tips would be great too.
Bob
