Hey guys,
I want to infuse a single skin of 240gsm 3k carbon with a double sided gloss finish. I have tried many different ways, most failed badly, but the last ones seem to be close to a result.
I am getting a lot of pin holes (as the pictures will show) and it seems to be spread randomly across the whole sheet on both sides.
The sheet is 55cm x 35cm of 200gsm 3k twill. Resin is Gurit Prime 20 LV with an extra slow hardner(http://www.gurit.com/prime-20lv-1.aspx) Ambient temp is beteen 25-30’C.
I don’t have a vacuum chamber to degas the resin, but I let it stand for 10min after mixing, before infusion. Infusion takes about 2 hours. I cut off the inlet 10 min before I close the vacuum line, could this be the problem? I also don’t pull resin through into the trap, as the flow speed is very slow at the end of the infusion, even if I leave the inlet and vacuum open I doubt I will get resin up to the trap.
I udes the 200gsm CF instead of the 240gsm as it is cheaper to waste on tests, could it be that the loose spacing between the tow is causing the cavities?
I just got some Prime 20 ULV resin with a lower viscosity, I hope that this would at least help in reducing the pin holes.
What am I missing? What am I doing wrong. I am pretty new to caul plate infusions, so don’t be gentle.
Regards
Jacques
