Hi all,
Second post - couple of months stalker (on the website of course). I searched on “thin overlays” and just a view threads showed up.
I am eager to try overlaying some parts but just as a hobby for now. I was thinking to do a thin epoxy layer, wait till it gets to tacky and than lay the cloth down.
An extra step that I think will help is to vacuum the part…since the parts that I would like to do are small, a food saver will do. As this is a good way for the cloth to adhere to the part via the resin. Would it cure properly if I seal the bad and let it stay in the bag overnight?
With that dry, since I put on a thin layer of epoxy - hoping that it didn’t soak through the fabric, how would I go along on adding the next layer of epoxy? Would another 1 layer of thin epoxy suffice? Or would I need 2 or 3 thin layers, sand down a little and then spray on clear coat for it adhere?
Also I was curious, I seen tons of overlays that have holes cut out for the screws to fit. Since I am just thinking of doing one layer 3k, how would this affect the cutting process? And would it be easier to cut once I lay down the fabric when it is still in stage b - or wait till it cures?
The resin that I would like to use is Kleer Koat by US Composites. I heard that It was thick and the viscosity of this thing is high, so the first thin layer of epoxy would be good for the fabric to adhere to the part.
