Thickness Problem Spraying Gelcoat
Hey guys,
Today I decided to be bold and take a stab at spraying gelcoat over a mold. I used a LVLP gun with 1.8mm tip (sprayed @ 45 psi). Fiberglass store sold me this and told me it would be fine for gelcoat.
After spraying the gelcoat, I like the uniformity it produces over the brush. My problem is that I can’t achieve the 20 mils thickness. It seems like I couldn’t even measure it with my thickness gauge.
Also I noticed for a small mold(~18"x18"), if I brushed it, I could get 2 coats of gelcoat in (way thicker than spraying but not 20 mils)while only using 6 oz of gelcoat. It took me a total of 12 oz of gelcoat just to get what seems like a surface coat over the mold.
Is this due to the 1.8mm tip? Overspray that I’m losing material? Is it dues to the gun being an LVLP?
Thanks in advance
Ahh the grand wastage… Spraying any material results in partial loss into the atmosphere. I believe LVLP guns can have as much as 25-45% wastage, which is consistent with what you are experiencing. HVLP guns are much better and can achieve as little as 10% waste.
I am surprised that you’re able to spray gelcoat with such a small tip.
So it is the overspray. I noticed there was quite a bit. Spraying with a 1.8mm tip was hard since this my first time ever using a spray gun. Could barely tell if anything was being sprayed at all. Looked like just air was coming out.
So would you all suggest a gun with a 2.0 mm tip in hvlp?
Gelcoat is thick, too thick in my opinion to spray with conventional guns that gravity feed or siphon feed (even if the salesman says it works). You need a cup gun (aka dump gun) or a pressure pot. My cup gun has a 6mm tip that I use for small parts. On larger molds, like a boat hull, if I had to use a cup gun, I’d probably opt for something even larger. My pressure pot has a fluid nozzle that is 2.8mm. A pressure pot pushes the gel out with about 30 lbs of pressure so you can imagine how much gel comes out in comparision to a regular spray gun. I can spray a gallon of gel in less than 7 minutes while carefully applying it. If I was just squirting it out it would probably be less than 5 minutes.
The cost of better film thickness control and less porosity is lower transfer efficiency (the amount of gel that actually stays on the part). Cup guns and pressure pots have a transfer rate of around 50-60%.
Now, if you really want to spray some gelcoat, you get a spray rig from MVP, Glasscraft, etc that can put out about 7lbs per minute (about 3/4 gallon) with high transfer rate (up to about 80-90% with modern equipment). The main drawbacks to these guns is they are better than $6000 for a new unit and they are not really made for spraying a few ounces at a time. They are, after all, production equipment.
That’s more like what I was expecting ^
With the extra material wastage, time spent cleaning equipment, and the health risks of spraying, this is why I brush as much stuff as I can. I even prefer to apply my 2k high build and clear coat with a brush (though admittedly I have only done this on one project so far) despite the extra time it takes to flat and polish it afterwards.
