Textreme question
Is textreme fabric better than other spread tow fabrics ???
I mean… I have a roll of material which is 160 gr/m2 which has exactly the same pattern and style like textreme . Is there any difference from the textreme one ?
Comes down to what you need. As long as it’s the same AD, same tow size, same sizing, and same fiber type, then both materials should behave the same.
Now, say they are both IM7 with a 24k tow. Same AD, but one has a smaller tow size than the other (and obviously thicker)…The larger tow size (say, 1" wide) vs the smaller tow size (1/2" wide) will act more like a unidirectional fabric. This could effect your layup, and your final part properties.
