I just wanted to run this by everyone here to see what feedback I would get, and possibly any tips that could help…
The photos below are from the first plug & mould that I made. I used an expanding polyurethane foam to shape the part, which worked well because I could form the shape quickly by cutting and shaping the foam. Then I used body filler to help get a smooth finish and build up any areas that needed it.
I think the big mistake was that I used a rattle can gloss black paint… Maybe I didn’t let the paint dry long enough, or didn’t use enough wax either… The mould came off the plug okay, but the plug was in quite bad shape…
I am going to be making some more parts from scratch, as well as modifying some existing parts which are made from ABS plastic. So, the questions are:
[i][u]Should I use polyurethane foam and body filler to build up & shape the plug? Or is there a better way?
Is a 2 pack paint necessary for the plug, or would a chemical resistant paint suffice?[/u][/i]
I think that body filler is okay as long as I don’t try and use it in a thin application, all edges of that plug are body filler (the most is on that lower front area, about half is bondo), it’s just the thin areas where I had troubles (I used thin applications on the top surface to help smooth out the shape).
I suppose I could just pour resin over the foam to fill the little holes, sanding it flat and using more resin to basically flow coat it if I got the foam shape close enough to what I wanted?
On the subject of paint I came across this today: KBS Diamond Finish which is chemical & fuel resistant, and they say harder and tougher than 2 pack clears. I also know about Spray Max 2k, but at the moment I’m not sure if I can get that into Australia or source it here… so I’m just looking for other options that might work.
If a 2 pack paint is necessary, I will just go that route, buy & mix my paint then use a Preval Sprayer. (That’s another thing that I just learnt about today, seems like the ideal solution for small jobs!)
I also saw a suggestion on another forum to cover the foam in latex house paint? They were specific that it must be latex - would that work?? Seems like it would still need a clear coat to get a good polish?
Another small question - you can probably notice the fibreglass texture visible through the gel coat on the mould. I think this is because I just applied the gel coat and didn’t put it on thick enough, and may not have waited long enough before proceeding with the job. The gel coat was tacky, could the texture also have come through from pushing too hard with a roller?
