A while ago I recommended Soller Composites 820 resin but I have since found some fairly major problems with it…
Essentially, when not in use, the resin turns into a thick (almost solid) white clump. They say (on the tin) that you can put it in an oven up to 200 degrees F to return it to a clear liquid state. That part is true but… if you try and use it when it is that warm then even the medium hardener makes it cure while you are stiring… instead of the 6 hours it is meant to take.
You can try waiting for it to cool down to room temp but then it goes back to being an overly thick white goo. A problem that gets worse over time, making hard to use reliably in a workflow.
The quest for a high quality clear room temp cure laminating resin continues…
