I ran out of resin and my supplier couldn’t deliver until next week so I decided to run down to West Marine and get a gallon of System West epoxy resin.
I used the 105 resin with the 205 fast hardener (5 to 1 mixing ratio by volume). I highly recommend getting the ratio pump by System West also. The resin wets out very good and the fabric stayed down much better than most other resins that I have tried. This resin cured to a very clear finish. Over all I like this resin better than the one from US Composites. However, it also costs alot more so you’ll have to decide for yourself if it’s worth the money.
If you’re working on small projects like interior pieces, this is a good resin to work with. It will cure at room temperature and does not require post cure. If you need something that can withstand high heat and/or take a lot of sun light, this resin is not for you.
i love it
