Ever get stuck on a part, tweak something and try again, its no good, tweak something again, still no good and tweak until you don’t know what else there is to try?
I’m on the verge of just quitting because I’ve spent lots of time and money with nothing to show for a small, simple part.
Material preface
Epoxy resin : West System 105
Carbon fibre: 6oz
Spray adhesive: 3M Super 77
What I’m trying to make:
What I have made:
Open wet layup method 1
1)In-mold resin clear coat left to tack
2)Lay down carbon fiber layers on tacky resin, brush on resin and rolled between layers
3)Let dry 24hours then pull
Problems when I do this: Massive bridging. I let the initial layer of resin to tack before laying down my first layer of carbon fiber but it still doesn’t stick even after rolling it in.
Open wet layup method 2
1)Spray adhesive on first layer of carbon fiber, gently work it unto mold
2)Brush resin and roll between layers as usual
3)Let dry 24 hours then pull
4)Brush on a top coat of resin, sand, wet sand to 1500 grit, hand polish with Meguiar’s M105 and M205.
Problems when I do this: The spray adhesive hardens into many little matte white dots as shown in the pictures below. Also, when I sand and hand buff, it’s not very shiny and under direct light I can still see scratches (the part is too small and thing to use a DA polish) PS Ignore the dremmel cut but rather look at beneath the top coat
I’m trying to do this WITHOUT vacuum bagging. I really don’t have much motivation to fund any more extra tools and equipment without seeing any results first.
