I recently had a guy bring me a sump guard he had from a rally car he is re-building, it had taken a few wacks and was in poor condition. On closer inspection what I initially thought was Aramid (because of it’s yellow colour) turned out to be a FG woven roving which was either tinted by the maker or by the oil which had fallen onto it over the years. It was given an outer skin which is either the same tinted black or more likely Carbon fibre, it looked like it was bonded and coated in Polyester and full of air bubbles:
I vowed to do better!
First off I cleaned and de-greased the best I could, then held the floppy (but still attached) broken bits together with glued on splints, filled it and rubbed smooth:
This is after I demoulded it, some bits came loose, but it doesn’t matter now - it’s only fit for the bin.
I then took a mould from it.
To make this from the thin Kevlar I have was going to take ages and cost a heck of a lot in order to build it up to a good thickness, so I elected to go 50/50 woven FG/Kevlar to keep costs down. I’m guessing you can get much heavier grades of Kevlar??
Here I made my only mistake, I still dunno why I did it as I’ve been working with various chemicals for years and know all about incompatability issues.
I brushed out a gelcoat of Polyester and proceeded to lay up using Epoxy…
I can only assume I was having an off day, The part came out fine, but soon started to blister and epoxy began to weep out from under the Gelcoat, I laid it out in the Sun for a month (!) whilst getting over what a nob I’d been and wondering how to get around it before picking it back up again, getting out my blowlamp, scraper and burning/scraping the gelcoat off.
I also reckoned it was a bit too thin. I sanded it, washed it with water and Acetone before commencing with more layers, this time it was an overlay! I picked up some tips on here and the Racing Comp forum and in the end it came out just fine. The seperate lip at the front protects the lower part of the bumper and was used as a good place for advertising on the original works cars, I made a simple mould for this from a length of MDF moulded to suit the profile.
All in all It’s turned out quite well and I learned a few more important lessons and tricks.
It’s going to get some metal skid plates riveted to the underside of it.
