Hello Ladies and Gentlemen,
Been reading alot on this site, and tried to take in as much info as possible. What a great site with a ton of info, thank you. Hopefully you guys can direct me in the right direction…
I designed a panel from 3d data and am having difficulties determining whats the best method of making the plug. The panel is about 20" x 38" with a lot of contour and will be made by infusion. Keep in mind, I only need to make 3 panels. Below is an image of the panel on top of the mold I designed:
(orange is the mold, grey is the panel)
First, the mold will be cut in a CNC so any material is okay, but I figured glueing styrene panels together would be the most cost effective. Will this be a good option or would I be better off using MDF boards? The only reason why I am avoiding the MDF is because the price would be almost twice as much. Trying to keep this project cost at a minimum (wedding around the corner).
Second, what is the recommended surface coating for the styrene? Should I use the products from Duratec or would a couple layers of fiberglass & tooling gel be better? Also, what can I expect for life of the plug? Will I only be able to get one part from the mold.
If I am way off on this one, please let me know. First project from scratch and a little nervous I’m going down the wrong road. Thanks for your time reading this and your responses are greatly appreciated.
Thanks,
Jason
