To anyone that uses Polyester in the process of infusion…
Do you add styrene to your mix to thin out the resin to get better flow? I typically use epoxy but have had some recent customer interests in using Polyesters.
Maybe I’m just an absolute failure, but from what I’ve found is that the cure time with epoxy is longer, so it travels farther although slower as it has more time… Polyesters cure considerably quicker, so I would like to get as much flow as possible.
My test:
Epoxy from 3/8" feed on a controlled subject gets 30" from feed
Poly from 3/8" feed on same controlled subject gets 12" from feed
Current product in question:
PE Clear Surfboard 249. It is thicker than I am used to for Polyester resin and not sure how well / far it is going to infuse… I know I know, test test test. Just wondering what the general consensus was with using Styrene.
Thanks guys, I greatly appreciate it!
-C
