The answer to this is probably obvious to a lot of you but is completely lost on me. When flanging a part does the clay (used to smooth the edge) affect the final geometry?
For example say I had to flange a flat plate with a 90 degree flange and I use clay to smooth the corner. Won’t there be a gap in the final part when I put the two pieces together? If you were to make that part you would end up with a circular edge at the flange. Below is a quick illustration of what I mean.
Black is the part. Red is the flange and the brown is the clay
