Hi, I’m completely new to infusion and making a few test panels before an attempt at infusing a hood for my racecar. My test panels are 12x30 inches, with a total of 3 layers of 2x2 5.7oz twill, and one layer of lantor soric XF (2mm). I’m using a plate of steel as my mold, grey mastic tape and nylon bag material. I have about 3 inches of sacrificial laminate on each end of the part. I have a single layer of peel ply and about 6 inches of green mesh on each end. The green mesh overlaps the section of material containing the soric by 3 inches or so. The spiral material is on top of the mesh, and I have another layer of peel ply covering the mesh, to prevent the bag from being pulled down into it.
I’ve done 3 test panels and each one has failed in the same way. With each one, about 5-8 minutes into the infusion, the bag starts to get slack on the resin side – especially near the feed spiral, and the resin pools inside the bag instead of proceeding through the part. Once this occurs, flow from the resin cup stops. The bag stays tight on the dry side of the part, and my gauge continues to read 29in Hg. I tested last night’s bag before starting, and it held vacuum with no measurable drop for 90 minutes before the infusion started. I assume I have a vacuum leak causing this, but I cannot find it. I’ve used a stethoscope, and clamped the feed line in the hopes of finding the leak once the bag goes slack, but I haven’t been successful. It seems strange that the bag would be fine for an hour and a half, then only leak once I introduce the resin, but that’s what has happened 3 times now.
I’m stumped, and could use some suggestions on how to troubleshoot and what to change for my 4th attempt at a test part.
Thanks!
