I have been really lusting to make my own mountain bike frame. I am essentially giving up street riding my motorcycle for family reasons and want to take to the trails instead. I also want to incorporate an electric drive system into the frame for kicks.
I envision making a system that is an electric mid drive ( powered by a motor located located near the crank where you pedal and driven by a belt or chain for boost).
My idea for frame design is similar to the size and geometry for standard downhill bikes. I would like to create a large hollow triangular frame section from the head steering tube to the seat to the bottom bracket. I would like to mount the motor inside the hollow frame (essentially a monocoque, but it would need one side of the frame open to be able to mount it all in there).
Triangular frame
One solid side and one cut away side for access to mount the motor and electronics.
Frame width at least 3" left to right
My question is how much of a compromise would it be to have the inner portion of the triangle of the frame cut away on one side?
What about adding some features for rigidity to the non cut away(solid side)?
please excuse my rough sketch.
hope you will do better
