Hello,
I ve roaming at the internet  for quite some time trying to find resins for infusion and i have this problem : Some resins have specifications that in papers are superior than the plates samples i am getting .
And let me get this straight - i ve been doing some test samples with 4 different companies - Fibermax Composites , Easy Composites , A. Andreou , Hexcel…(prepreg not infusion) which are not a lot but these are the ones i could get materials from - all the rest companies (most …i havent contacted with everyone in the world yet) .
What i can say is that i am confused . Sorry for the randomness of what is going to follow …
What resin do u use for maximum strength ?
I am talking infusion resin and prepreg -
What is the difference between OOA prepreg and autoclave prepreg?
And let me make the question more straight - Is it possible to achieve professional results (consumer grade - things that can be sold and bought like bike frames, helmets ,Bike rims -… not F1 cars)
with OOA prepreg ? with just vacuum ?
For example the datasheet of a prepreg i am using from Fibermax says that it can be cured with or without autoclave…but the properties table is not different between autoclave or not process … So why use autoclave ??? -
While infusing is it critical to have full vacuum ? I made a setup with a pressure switch and because i put in between a 3 litre chamber as a buffer i can not get full vacuum …my pump seems to be weak and can get up to -0.9 Bar … not -1 …is the part just a bit more resin reach or are we talking of inferior part.
