I could use some suggestions on layups and support for a large mold. It is 35 feet long and about 18" wide and shaped similar to a rowing shell. I estimate about 10 square yards of surface area for the entire mold including flange. When not in use the mold will be hung from a ceiling at two points. When in use it will be set on saw horses or tables. I would like the mold to be stiff enough that it holds its shape when supported at 2 points. I would like to use tube bag when I make my parts so the external skeleton cant be too large and the mold can’t be too heavy. Are these goals reasonable? I have found a few pictures online of similar molds and they have an exoskeleton of truss that extends to the floor. I have also seen some that appear very flexible but are set in a cradle.
I can use an unlimited amount of:
epoxy resin
24 ounce biax fiberglass
For a very low cost I could use 19.7 ounce carbon fiber.
I am not opposed to purchasing other material if needed.
I am having a hard time deciding the material and strategy for a core. I have considered:
Western red cedar - heavy.
XPS pink or blue foam - dents easy. With enough cloth this doesn’t seem to matter.
PVC tube cut in half length wise - The weight adds up quick.
divinycell or core cell - expensive and hard to ship where I am.
I have built a very similar mold that was 24’ long. It used 4 layers of 24 ounce fiberglass with epoxy resin. There was a 5" wide stringer made of 1/4" thick by 1" wood strips down the middle sandwiched between the fiberglass. This was adequate for the 24’ but would need to be significantly stiffer for 35’.
If i used the pink foam I would use 1" thick and cut strips 3" wide with a taper on each edge. The taper makes it easier to lay the cloth.
My current plan for the mold is:
2 complete layers of 24 ounce over the entire mold.
Over the middle 25 feet add a stringer of pink foam down the middle and ribs between the flange and the stringer every 2-3 feet or so.
Two more layers of 24 ounce on top of the middle 25 feet of the mold.
