Would we be able to get a sticky going regarding the resins that we’ve used/are using? It’s hard to determine properties of a wide array of resins when you can’t actually use every one out there. The sites I’ve seen usually give vague descriptions. The veterans probably have a lot of info that could be useful. Thanks.
http://www.compositeforum.werksberg.com/showthread.php?t=1345
Just post the maker, contact information, type, part number and any other facts on the resin.
Sounds like a good idea to have a sticky just showing various resins people have used. We’d need to come up with a format to keep comparisons consistent, and brief.
Would be good to include:
Viscosity
Clarity and Color
Mix ratio
Time to gel & cure
Service Temp
Strength and Stiffnes
Maybe even a sentence or two describing its workability or experience hand laminating, infusing, or vac bagging.
also some pics of standardized thicknesses we’ve cast just for comparison… say 1-2cm thick or whatever…
