Of course it will be carbon fiber walled.
Gruit ST94 prepreg, unknown fiber. 1.5" Pink foam, I hope the R-value is enough for a small fridge.
Do some quick calcs on the heat loss! It’s a simple two variable equation with one constant!
You and the fat twills, I love it! Can’t wait to see this finished. How are you bonding the walls with top and bottum?
is that the low temp prepreg that gruit do?
Is that vac bagged and ovened or is it autoclaved?
Your building a carbon fibre fridge???
Rotor, I’m bonding the walls and the bottom with sprayfoam. Insulative and i hope adhesive. The 2 cans I had started to leak out the base of the nozzle, NOT actually come out the tube. Back to HD!
Matvd: yes, ST94, 16hr at 71c. It didn’t melt much, but softened the flanges I had. That might have been a bagging issue though. I simply wrapped the foam, wrapped in solid release, put both in a bag with airweave between them, and tightened the bag on the surface. VERY good surface finish, except for 2 of them, I think outgassing got trapped. Pure oven, no autoclave…the foam is rated I thnk, only at 15-18psi, so vacuum was enough.
