http://www.compositesworld.com/articles/sqrtm-enables-net-shape-parts
According to the article “In short, SQRTM is designed to produce an autoclave-quality part without the autoclave.” Has anyone seen this method before or use it? Seems like those of use that can’t afford an autoclave could make parts to the same quality or higher? No?
Edit: “Also unique to the SQRTM process is the level of vacuum used, Coughlin adds, pointing out that Radius develops its vacuum pumps to create <0.5 mm/Hg, which is “more vacuum than a standard shop pump can produce.”” What kind of vacuum level is that in inches?
