First let me take this opportunity to thank all of the contributors on this forum for providing a portal for those of us that are learning. Thanks!
Now to my question or questions.
I am building fiberglass intake manifold runners for prototype testing purposes. Think of a pipe but with changes in geometry throughout the length of the pipe. It is approximately 12" long with changes in the X, Y, and Z axis throughout the length of the pipe. It also changes in size from one end to the other. For this reason I made a plug from fiberglass that mimics the interior shape.
My questions are on the easiest or proper way to make these runners.
My first plan is to use my plug to make a two part female mold. With this mold I would make male foam cores that I could layup with fiberglass. I would then disolve the foam to yield the finished part. This would yoield a nice interior runner with no seam line. Is this feasable?
If so what type of spray foam do I use and where do I get it?
The spray foam from the home improvement stores seems to stick to everything.
What would be the proper way or material to use to disolve the foam from the runners after layup?
I had planned on using plaster for the female mold maybe I could use silicone instead to avoid the sticking? What would everyone advise for this?
The other option I was contemplating was to make the two part mold and make the manifold runners in two pieces with a flange to join them together afterwards. Of course then I have the cleanup of the seam lines on the interior as well as the exterior cutoff and smoothing of the seams. I could do this but would prefer the first option for it’s smooth interior.
I would appreciate any help or advise you guys could give.
Thanks!
