i see there is a spray adhesive to keep the dry fabric from moving around on the mold surface when using polyester. is there something similar for use with epoxy?
same glue. Use it sparingly, go lightly with it, or it will mess up your part.
Never spray it on the mold surface, spray it onto the fabric itself.
3m spray adhesive 77
I used that for lay up cloth but once PER resin wet out it’s free to move again, is there anything that can keep it in place even after wet out the cloth?
what exactly are you trying to do? open molding? do you really need the material to stay together for that? most people use spray for infusion and some other applications. if your having problems keeping your material together you may need to use a vacuum
