So I started the clear coat thread and I guess this would be the follow up to it, haha.
I have a makita buffer with a few different flexible hook and loop pads, cutting compounds and such as well. The smallest one I have is a 3 inch but it’s still to large for some spots and also the hook and loop doesn’t work that well when you are forcing it into corners.
Since corners don’t particularly need to be polished like a flat surface it’s not a huge deal to me but they still need to look good and also I’m having issues with my 3 inch wool pads.
I’m wondering what you guys are using do right corners or even 90 degree angles. I thought about the mothers powercone attachment but it seems that it may not work.
Also an issue I have is I have a very thin run of carbon… It’s about 1/2 inch wide, 10 inches long and 1/8th thick. I feel as if it will snap if I mishandle the buffer. Any help would be appreciated. I also though about making some type of device to hold my buffer down and I can move the part freely.
