Hi all. I think I’ve seen part of some of these on older threads, but I find they don’t get as much reading as the new ones, so here goes, in no particular order:
*Can a braided tube be cut and used as a flat sheet?
*If yes, for the above, is there a good technique for keeping it from unraveling? I was thinking of masking tape lengthwise, which would then be cut through; would the tape adhesive be a problem for the fabric?
*Anyone have experience with home made syntactic foam, i.e. glass microshperes like from Fibreglast?
*The description of the Aventador’s chassis production process sounds a bit similar to the composite space frame idea ATR demoed five years ago; does anyone know if there’s a tie-in?
Thanks!
