I am experimenting with molds in order to fabricate some carbon parts for my track bike, my first couple of parts are coming along nicely and I am repeating early mold prototypes to perfect the techniques, finish etc.
However, my early parts and molds are simple brackets so there are no complex shapes or angles to deal with.
I’ve just formed a mold around a rear fender as a trial and the mold has turned out surprisingly well.
However, this test mold has highlighted that it would prove quite difficult to form a good carbon part using wet lay up techniques due to the tight corners. More specifically, there is a fixing hole in the original part which can be seen in the top centre of the mold in the image above which will be impossible to lay carbon into and achieve a good finish.
So I have the following question, should this part (and others of similar shape and complexity) utilise a 2 part (or multiple part) mold???
I’m already wondering if I should split this mold as a trial and have a go at forming 2 parts which are then resin bonded together.
In this instance, an ideal parting line would be (when viewing the image) from left to right along the back recess just below the centre fixing hole, since the upper part of the mold would not be viewed on the finished part once installed.
I’m also starting to practise with some vacuum forming, but this doesnt detract from the need to split a complex mold - I dont think!
Any advice welcome, here is the original part out of interest (in pre mold preparation)
