So i have been using this Epoxy Resin for a few years now. I have used it for many Overlays and Wet Lay Applications. Uber Clear, Excellent finish.
“SP 115 is a low viscosity, ultra-clear epoxy laminating system. It has been designed for the manufacture of laminates which are to remain unpainted, and where a very clear finish is required. The material also contains blue UV filters which give the product its characteristic transparent pale violet/blue colour.”
Good Points:
Uber Clear.
Good UV filters.
Easy wet out application.
Bad Points:
Exspensive (~£40 for 1kg pack)
Very long cure times at Room temp. (14 days at Room Temp)
Overall, this is a very good resin, really easy to use and really good results can be achieved with it. Altho it doesnt have a massive high temp range, i have used it on engine covers and its been ok. This could be the only resin i would use if it cured alot faster.
I would rate this at 4 Stars
