What is the vacuum prob that be used in composites work called. My half-ass description goes like this: it is a quick released fitting. You put one end inside the bagging, then like poke a hole for the fitting and like attach your hoes. This is used to pull vacuum easily and not have to route much tubbing.
What leak detector are you using?
What spray glue do you use to keep your fabric from moving around on the mold?
Are you using an electric polish to buff your molds? I have large molds and this would greatly reduce time.
thanks,
Big
