The mold for the cover was sanded to 1200 to remove any imperfections, and then waxed several layers, which were allowed ot dry over night between applications, then a lice thin layer of pva was sprayed on with no orange peel happening, very smooth.
I am using Ad-tech 820 epoxy infusion resin, where the total viscosity is around 350 mixed, I apply a bit of heat to the mold to get temps up and the viscosity a bit lower too. The resin was degassed under about 25inch Hg for about 5-10 minutes. then allowed ot infuse. There were no leaks of any sort the parts sat under vacuum with the pump turned off for a long while , while I mixed the resin/hardener and degassed/ got ready etc…
I can’t for the life of me get a decent consistent infusions.
I find that bubbles remain trapped under the peel ple and even within the flow media and don’t move away… The best finish I seem to get is if I place a minimal amount of peel ply and flow media over a flange part that will not actually be part of the trimmed piece and let the infusion take place just through the reinforcements. But this takes a LONG time and if the stuff kicks before it’s infused all the way, I’m hooped…
even over the areas covered in peelply and flow media the infusion takes place quite slowly, I only had a single layer of 5.7oz twill and then one layer of 12oz twill.
Also, when I do get areas or parts where the surface is pitted with bubbles or voids, the corresponding back side with the bag over it never looks like this, it looks perfect!?
any help would be great!
