OK, then its definitely not as easy as i had hoped it would be.
it seems that in order to make a well performing tooling coat i would need to get another education in chemistry, and then add a few years of trial and error to nailing down the perfect formula…
since neither of those things is going to happen, i suppose ill skip it and just invest in good materials.
to ask a more pointed question though:
in our prototyping phase, this is the way im doing it. eventually if it all works out we would have proper tooling machined by a machine shop… or maybe i buy a nicer machine
i am directly CNC machining female molds. in a perfect world, these would be made from aluminum or steel. my machine isn’t capable of that at this point. a step down from that is to use corian or other acrylic solid surface countertop material, which ive done a few times now have had great results.
at the lower-quality end of this spectrum i have been roughing the molds out of MDF. i over-machine the molds to about .020" past the OML. then i apply several layers of gelcoat and re-machine the gelcoat to the proper OML with a fine stepover, then sand, polish, etc etc etc.
can you guys recommend a good quality tooling coat or gelcoat for doing this? it needs to be sandable/polishable but still durable enough for scratch resistance.
at this point these molds are designed for infusion with epoxy. we may try other resin systems eventually like vinylester and or methacrylate, which seems very interesting…
thanks for any help, and for the education!
-david
