I have had problems to solve how to operate my vacuum pump with SMC vacuum switch. Any shop that sells those seems to not know what kind of output signal those switches give. I even gave SMC a call, but they neither didn’t know. On SMC data sheets there is wiring diagrams, but they use unfamiliar drawing signs to me.
So does anyone know if these switches give the same voltage out as operation signal than the power supply that runs the switch?
Like 12Vdc switch can operate 12V relay, and 24Vdc switch can operate 24V relay?
