I agree, infusion is better.
But, doing large hulls like that can be done hand layup in several ways.
Like DDcompounds says, or layer by layer. Start in the front or at the ransom, and work from there. Some minehunters are build like that. Check layer, sand, repeat.
maxe sure you have an unwaxed resin though, but that’s the same for most applications.
Multiple layers can be done as well, again start at the same point, but then add a second one if you move on, another first layer, another second on the patch you just laminated the first layer, third on the 2 layer patch, etc. But it depends on hullshape and complexity and how many laminators you can work with at once.
shrinkage can be an issue, so I would be careful building up a lot of difference in thickness in the same product.
