Small isotruss pipes - how construct?
Hello
Looking for some thoughts on best way to make carbon fiber isotruss
Along the lines of the below link - but on a smaller scale
https://spinoff.nasa.gov/Spinoff2007/ip_1.html
Had thoughts to explore using methods similar to these to create the pipes :
https://taubmancollege.umich.edu/research/research-through-making/2014/c-lith-carbon-fiber-architecture
http://www.dezeen.com/2014/05/28/il-hoon-roh-carbon-fibre-luno-armchair/
But raises few questions :
What tape is being used in each? Each seems to be prepregnated, with the first being a very then roll, and the second a wider tape cut, folded, and twisted.
Alternatively could a isotruss be reasonably constructed by wrapping carbon fiber filament (ie the wire used in 3D printing machines ) around a frame?
Please note the hobby construction I looking at will have reasonably high weight / glitches on it. Tube will be quite small
Any other thoughts best way to explore ?
Cheers
