I have been making silicone vacuum bags recently and had to work through a bunch of issues. Most of the problems were related to the biggest strength of silicone - it doesn’t stick to anything except silicone and glass…
I used the brush-on silicone vacuum bagging product from Smooth-on. They have two. The other is a spray-on silicone but I went with the brush-on platinum cure product for cost reasons.
The first issue is sealing the bags. When I researched it online, most of the solutions seemed beyond my skill and patience so I developed my own method.
Instead of using tape to seal the edges, I used more of the brush on silicone to make the bag all one piece with the exception of one side to allow me to insert the mold.
To seal the remaining side for the vacuum, I glued on a regular reusable bag seal which I cut off a Home Depot vacuum bag. You would obviously use something rated for high temp to seal it. Whatever you use today will probably work.
I used Sil-poxy to glue the bag seal to the silicone bag. This is the only product I found that worked for this purpose. It’s not cheap but none of the silicone based glues I tried were even close to being effective at adhering to silicone reliably.
I also use the sil-poxy to stick the vacuum bag connector to the bag and seal the edges. This isn’t 100% necessary but I like to eliminate the leak potential where possible.
All that worked just like regular vacuum bags but with the benefit of not needing the release film etc. also, because the bag was made in the shape of the mold cavity, it just goes right in without any pleating and all the other tedious parts associated with bagging complex shapes.
I also work with two-part closed molds (mostly) and I am still working on a reliable process to do it all as one step. I have decided that, for my mold design, it is most likely to work if I use the silicone vacuum bagging product to make an inflatable bladder instead of a bag.
The process of making the bladder (which I haven’t yet finished) should be broadly the same as making the custom bag except I intend to add a one-way valve instead of the vacuum bag connector.
Based on my experiments with the bagging silicone and sil-poxy, I am fairly confident the bladder process will work once. I am not 100% sure how reliably it will release from my part for a second and third use though. It’s not that hard to tear by mistake on a sharp edge…
For simple shapes like a pipe / tube or a square box, I am positive a silicone bladder would work and release cleanly. Silicone usually has fairly good heat resistance too. I haven’t checked how much heat the bagging silicone can take but I have had some of my others in the oven at 300-400f without issues. I cast tin and pewter in mold max 60 molds.
It is easy and cheap to buy silicone vacuum tubes too. Thinking out loud, maybe one could be built right in to a silicone bladder and stick reliably without additional glues.
To be honest, I am not sure I would buy the bagging silicone again for regular open mold bagging. I was able to achieve my desired outcome just as reliably using regular silicone inserts in between the part and a regular vacuum bag.
For a simple straight pipe / tube shape, maybe you could use a more rigid silicone rubber (like Mold Max 60) to make a male core insert. You could then wrap the prepreg around this semi rigid silicone cylinder and then insert that into the two-part female mold for curing.
I have read about companies using compressed air to reliably remove the silicone from inside the pipe after curing. I have used a variation of this myself to make cf tubes. The difference with what I did is that I wrapped the outside of the tube with smooth release film instead of using a female mold as I was only interested in the internal diameter of the finished tube.
Smooth-on sells trial size pots of their bagging silicone for less than $30. It is worth giving it a try.
