I’ve gathered that if injested into your lungs as a vapor, the danger is when you exhale your lung tissue can actually stick together. This naturally would be a bad way to go!!! Not concidering what it can do once in the bloodstream. Cast iron dust gives a sweet taste in your mouth but won’t stick your lung tissue together. The issue there is you can’t expel(cough up) a large amount so you have to have your lungs scraped. It’s what you’re not aware of that will kill you.
How many people use thinners to wipe off resins which simply helps drive it into your body. Use two gloves on each hand so you can rip the soiled glove off and move on.
It would be great to be able to spray Epoxies but I’ll let someone else jump on that hand grenade.
riff42 Thanks for the input, I here a lot about the PP being a pain if things aren’t just right. My buddy down under had PP on 3 layer wet out at the same time. Rolled out, then the next day they would rip the PP and light sand any spurs. I’m thinking he had enough layers, the delam wasn’t an issue for him and the faster kicking PER.
I was thinking of rolling the PP on top and wait till the green stage, then wipe the excess resin off of the PP with a thinner. My thinking here is the resin is working like a rivet through the PP. If I remove the head of the rivet, It will not want to delam the project. A heating blanket at 100* for three days to help post cure the layers is suppose to add roughly 20% integrity to any epoxy, might help keep things put. Is this crazy?
