I’m trying to make some custom silicone rubber plugs using a female polyester gel coat split mold. When I release the mold, the silicone rubber is sticky / gummy on the area which have touched the mold.
Here’s what I’ve been doing:
- Machine a female split mold from mdf on my CNC router
- Apply polyester gel coat and let it cure
- Run a final pass with the CNC router on the cured gel coat to get a smooth finish
- Sand the gel coat up to 600
- Apply Meguiars Mirror Glaze 87 release wax (containing carnauba)
- Fit the two mold parts together
- Mix shore 40 A silicone rubber according to specs
- Pour rubber in mold
When I split the mold, the core of the plug is cured nicely. The surface however is very sticky. Also the surface of the gel coat mold has this sticky stuff on it.
The silicone rubber in the cup in which I mixed the rubber however cured nicely without sticky surface.
When I remove the sticky stuff from the gel coat mold, the gelcoat itself seems untouched.
Does anyone have any idea what goes wrong here?
Thanks a lot!
