Hi,
I would like to make a mold out of silicone, but w/out significant amount of layering, most is pretty soft for the reasonable priced. So far, the hardest I’ve found is probably around 60 shore. Does anyone know of a cheap, good backing material that will stick to silicone. I’ve seen people use the spray foam, but that, too, comes off quiet easily. I thought about sandwiching some sort of a mesh during the pouring process to harden. But I don’t think that will work well if i’m trying to create a complex shaped mold. My ideal thought would be to use the silicone w/ a thin layer, then pour something on it that has a strong backing w/out it coming off. don’t mind being permanent.
Any suggestions?
Thanks,
