I want to make an inflatable mold for a carbon handbrake lever i plan on making in pre-preg. For the mold itself, i’m using PTM-W 2520 with a 1945 surface coat, which is rated for about 330F but the prepreg i’m using is 250F cure. I have some donated uncured silicone sheeting that AirTech donated to class. Its about 1/8" thick, and probably overkill for the size of this part (~14").
I plan on first doing a vacuum bagged part of each half, and then using that offset to vacuum bag and cure each half of the silicone. HOOOOOW do i combine the cured silcone halves?
Here’s a pic of of the part for reference. Its a wetlayup part that I bought…that immediately broke. -_-* Any help would be appreciated.
