I have been producing in-house silicone bladders for a bit for two part closed mold layup. I have had very good results with both brush in and dragonskin silicone from Smooth-On. The dragonskin is significantly thinner yet has a very high tear strength. I switched to the brush in and use the silicone thinner (10% max by volume), which aids in areas where you may need a little less viscosity. Actually both products work very well together and I will often ise dragonskin for the initial layup of the bladder followed by the thicker brush in for internal intensifiers or for bridging the two halves together.
You will need to de-gas after mixing, so keep that in mind. I usually lay up the two mold halves in 2-4 layers with about an hour in between, followed by a bridging bead applied to the ridges of both sides and then clamp the mold together. The highest temps I use for curing is 275, but the bladders don’t have any issues at those temps, it is rated to 450 f.
Let me know if you have any specific questions about the process.
