Hello to everyone.
I want to create an aluminium mold for the construction of a prepreg saddle. I want to lay the prepreg on the mold then put a silicone piece that will have the morph of the hole engraved by the cnc on the aluminium .Cap the top and screw it with a piece of metal and then let the thermal expansion of the cured silicone to apply pressure to the walls of the piece.
- How does it sound as a theory to you ?
- Is there a way i can calculate the pressure that will be applied at the prepreg with the expansion of the silicone ? I can calculate how much the silicone would like to expand , but i dont know the result of not letting it to expand measured in bar ?
3)Does the hardness of silicon rubber used effect the pressure effect on the prepreg ?
