For those who use this method of vacuum infusion/vacuum bagging.
those look good. anyone used them?
I’m assuming you have to tape the hose to the port even though it’s not done in the image, right?
The ports can be used in vacuum infusion, pre-preg, wet lamination vacuum bagging and other techniques using a nylon vacuum bag with Tacky Tape.
The picture does show the use of a tacky tape . If you look close you can see that it was cut and placed around the opening . Costing nearly as much as the aluminum thru-bag fittings , I would think it’s price could be lower . Just my opinion though .
ahh crud… you just reminded me i need to replace my vac bag connector - it got lost in the great abyss somewhere.
